Android Beta 5th August 2015 Version
Hopefully; though it does rely on us reliably reproducing it in the first place. I had a quick go the other day when I saw your original thread, and failed.
srayne
srayne
Posts: 388, Visits: 8.3K
Tim Dawson (8/10/2015)
That behaviour is by design, and finally matches our iOS version. If underneath your finger is only one airfield, SkyDemon jumps immediately to the information for that airfield. You can always press the Back button if you want to look at the information for the other items. Usually you don't, though, which is why it works this way in the first place.
OK thanks.
The issue regarding pinch zooming is not something we will be able to address in the 3.4 timeframe, sorry.
Hopefully you'll be able to fix it later?
Thanks,
Simon
InfrequentFlyer
InfrequentFlyer
Posts: 40, Visits: 732
I can confirm that.  This behaviour appears on 3.4.0.28538 (on a Samsung Galaxy Tab S 10.5) but appeared to work OK when reverted to the previous 3.4.0.26498.
srayne
srayne
This beta has broken the airfield popup menu. Press and hold on an airfield on the map and the location menu pops up and then immediately jumps into the airfield menu so am unable to select co-located waypoint/airspace/ndb/etc info from the location menu.
The pinch zoom problem is still happening (see earlier thread) on both of my devices.
What else changed in this beta?
Simon
SD Android Beta Version 3.4.28538
Nexus 7, Android 5.1.1
Oneplus One, Android 5.0.2
