Aircraft Size?
dyker124
dyker124
Posts: 10, Visits: 11
SkyDemon for Android
On my 7" Tablet, the little yellow aircraft that moves around the map when I fly has two size options of which I use the smaller one. Could I suggest that we have an even smaller aircraft option as I still find the smallest one still too large on the map for the smaller navigational exercises.
Roger
Edited 5/23/2015 3:03:08 PM by dyker124
There are at least fifteen different sizes you can choose. You should see a stepper control (with plus and minus buttons) to change the size, just under the option to change the symbol.
dyker124
dyker124
My apologies. There are indeed fifteen sizes of aircraft. I hadn't tried the bigger ones. I was suggesting a size that would be progressively the next one down to the smallest one that's available as I don't find the larger ones of use. Or even perhaps remove two of the largest in the list and add two more even smaller ones at the small end of the list.
Roger
Thanks for the clarification. The symbol size is defined in tenths of an inch and currently the minimum is 0.4. I have no problem reducing that to 0.3, which we will do for the next software release.
dyker124
dyker124
That's excellent. Thank you very much indeed.
Roger
