Local storage of charts
jollyrog
jollyrog
Posts: 24, Visits: 24
Can I (registry edit perhaps?) change the folder where charts are stored?
Currently they're going to  %Username%/My Documents/SkyDemon/Charts but this is a real pain, as I access that folder from remote machines using VPN. On those remote machines, the time taken to drag the charts across the VPN tunnel is making those SkyDemon installations unusable. Hundreds of Mb of charts backwards and forwards... no go!
I'd like to force the charts to go to a local drive. Happy for the Aircraft, Custom Data, Logs and Routes to stay where they are.
Thanks.
No, there is no registry key or setting to move that data.
leegent
leegent
Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)Too Much Forum (352 reputation)
Posts: 2, Visits: 6
You could look into making a directory link with the DOS 'mklink' command.
Make/move the data folder to where you want it then do something like 'mklink /d Charts d:\somewhere\else\Charts'. Make sure you start your command prompt with Admin privileges.
I do this sort of thing all the time to trick games into putting saves in my Dropbox folder for 'instant Cloud support' ;-)
Edit: of course, having multiple simultaneous instances of the software on multiple machines accessing the files simultaneously probably won't end well...
Edited 2/2/2015 2:39:12 PM by leegent
