Pseudo ILS available on user made runways?
Isaache
Isaache
Posts: 10, Visits: 27
I made several airports with DataCreator.exe filling all the available fields (Length, Width, Identifier, Alignment, Threshold and Elevation) however I'm not seeing the pseudo ILS while SD is in simulator mode and within the prolongation of the runway axis and the vertical navigation window shows the aircraft in descend after the Top of Descend waypoint, is this as per design or am I doing something wrong?
Isaac
Isaache
Isaache
Hmm, interesting, the pseudo ILS does not seem to work on the PC version of SD, but it does work for the iPad, good enough for me, as I already got my own response this post can be ignored.
Isaac
SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)SkyDemon Team (665K reputation)
Posts: 8K, Visits: 9.1K
It's the same code for both, so you should see no difference.
Isaache
Isaache
As usual you are right, the pseudo ILS does work in the PC version too.
Isaac
