Visits: 2.2K
I went and re-checked the problem (see example given in the original post), and it turned out to be a bit different from what I remembered.
The route field of the flightplan is OK, in that there is no specifically inserted waypoint for a border crossing. I seem to have placed a waypoint a bit besides the intended reporting point of OSMOT. However, in the "Extra Information" field I find the entry EET/LJLA0013. What ATC want to see is EET at a specific border crossing point. In this case there ought to be a EET/OSMOT0013 in the respective field. If I don't specify a border crossing point for coordination they are asking for one in every case.
My suggestion would therefore be: If a border crossing point was specified in the route field, use that to report border crossing time. In this context, I regard a border crossing point any point published in the AIP that is part of my route and not more than, say, 5 miles from the actual border crossing as measured along the planned course. If no border crossing point is defined becase (a) I forgot to include it in my route or (b) it isn't published in the AIP, fall back to your current method of reporting only the time of border crossing.
In a VFR flightplan DCT is superfluous and a thorn in the eye of at least Austrocontrol. Would it be possible to omit the DCTs if the type of flightplan filed is "V" (i.e., VFR)?
Greetings, -- Chris.
