New PLOG Printing Options
PlusoneToo
PlusoneToo
Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)Too Much Forum (143 reputation)
Posts: 1, Visits: 10
Here's a new one I thnk
Ive updated to the current version of SD and using a Mac. The waypoint names in the first column of the plog, which are now in different colours for each leg,  are not printing. All the other info is printing correctly but not the waypoint names.
Everything looks ok on the print preview but not translating to the final print, whatever paper size I choose and no errors reported from the printer which is a Canon inkjet.
If no one else is getting a problem Im putting in a late request to the big guy with the white beard and red suite for a new printer.
Hugh, which bug are you referring to?
G-OIBM
G-OIBM
Posts: 71, Visits: 946
A couple of posts earlier you said:
"Ok, thanks for persevering. I've located the bug causing the waypoint text sizes to be wrong and fixed it. It's all down to what happens when you ask SkyDemon to show more columns than can comfortably fit, especially when you're asking it to fit them into an A5 space. I've also tweaked the table generation so it reduces the cell padding a little for A5 printing, which will help things fit without shrinking the font size more than necessary. "
This is the bug I'm referring to, and the one I think is causing my printing issues.
Hugh
Hugh
G-OIBM
Commander 114
Ah yes, thanks. That was one indeed fixed.
kennet.stenberg
kennet.stenberg
Posts: 9, Visits: 44
PLOG printing in ver 3.1 for PC works good even when adding all columns, even if the flight leg data becomes a lttle small
That is not the case in 3.2
It´s not readable if you don´t remove columns down to nine or so...
And the PLOG font sizes differ a lot in 3.2.
Pete
Pete
Posts: 129, Visits: 959
So, as I understand it, Tim says the printing problem(fonts) has been fixed (several posts ago), but a version with the fix has not yet been released?
When can we expect a fixed version to be released?
Pete
Version 3.2.1 is just around the corner. We tweaked several PLOG-related things in that version. If there are still problems for anyone running 3.2.1 (once it is released) please get back to us, ideally with a scan/screenshot, explaining what's wrong and how it was better before.
Pete
Pete
OK just done a couple of plog printouts for PC ver 3.2.1 & 3.1.1 , two per page.(my pref for scribbling space)
0001 is 3.2.1
0002 is 3.1.1
Personally I still prefer 3.1.1 as I think the freq's take up far too much space and soon become several pages when going further a field.
Pete
Edited 2/10/2015 5:39:48 PM by Pete
lhe
lhe
Posts: 154, Visits: 445
I agree.
Unfortunately, we've had feedback from people saying it should be larger, and from people saying it should be smaller. I think I'm going to have to just make the font size an option.
