Print Centre Weather Briefing for multi-leg route (SkyDemon Plan V3.2, Windows 8.1)
Print Centre Weather Briefing for multi-leg route (SkyDemon Plan V3.2,...
srayne
srayne
Posts: 388, Visits: 8.3K
Planning a multi-leg trans-European flight from UK to Croatia. When looking at the weather briefing in the print centre for each leg the briefing is not always for the currently selected leg.
I've looked at the code, and it certainly should be. Could you come up with a couple of simple steps which consistently reproduce the issue for you, with a multileg trip?
srayne
srayne
Tim Dawson (11/26/2014)
Using SkyDemon Plan (V3.2) on a PC (Windows 8.1):
1) Create a new route direct from Cambridge (EGSC) to Split (LDSP).
2) Insert a waypoint at Memmingen (EDJA) and mark it as "Land Here"
3) Select the Cambridge to Memmingen leg as the active leg and click the button bar icon to activate the "Print Centre"
4) In the Print Centre select "Weather Brief"
The displayed weather brief is entitled "Cambridge - Memmingen Weather" but the weather entries are for the whole route including Split and is displayed in a seemingly random order.
Simon
