Merge flight logs?
schweboo
schweboo
Posts: 21, Visits: 71
I flew yesterday and lost the GPS signal (and had a Sky Demon) crash several times. Consequently, I have multiple flight log files for the trip. Is there an easy way of concatenating these files to make a single flight log - albeit with a few gaps here and there.
I use SkyDemon on an IPad and use a Dual Electronics XGPS150A.
Flightlogs are, I believe, XML files with a fairly simple structure. Technically you can join them using a simple text editor if you know what you're doing.
milansmid
milansmid
Posts: 68, Visits: 565
After the new flightlog format, how could I merge multiple flightlog files?
Before the change, it was fairly easy and the gpsvisualiser.com could read it as well but now neither seems possible :-(
Thank you for any help.
Milan
SD version 3.0.6
Once a flightlog has been converted from textual format to binary format, which happens the first time you open a log for analysis or back it up to the cloud, it is no longer straightforward to merge it. Mind you, it wasn't straightforward before, as lots of calculations would have been necessary to make the elapsed time column correct.
jan.schreiber
jan.schreiber
Posts: 11, Visits: 90
i second this, did the first two legs yesterday (each 250nm) using SkyDaemon as primary navigation (backed up by VOR) i lost GPS for a short period on both legs, ending up with 4 logs. It would be *really* handy to be able to merge logs in the app or later on in the planing software!
kind regards
jan
Edited 7/4/2014 7:24:49 PM by jan.schreiber
jan.schreiber
jan.schreiber
thank you guys for the last update. Merging worked perfect an all my logs ;-) Very cool!
Perfect now would be an option inside SkyDemon that doesn't cut logfiles at all when the outage is less then a minute or so. ;-)
Kind regards
jan
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
+1
mike@edtg
