Instructions for installing on PDA
johnm
johnm
Posts: 12, Visits: 23
Sorry Tim
I cannot find any instructions on how to install Inflight. Could you post a link please.
thanks
http://
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
The instructions for installing "SkyAngel InFlight" on a mobile device will vary according to the device itself.
Basically you need to end up with a folder structure of:
SkyAngel InFlight\SkyAngel.exe & Data\  Ireland.skydata   UK.skydata  W020N90.DEM
either on an SD card or in the Windows system.
If you let us know which satnav device or phone you are trying to install to, someone will (hopefullyBigGrin) come up with an answer.
Regards,
Max.
PS. Tim, very strange line spacing?
Doober2004
Doober2004
Posts: 42, Visits: 256
I have a Navman S70 which is unlocked and running MioPocket which makes it behave like a pda.  It connects to my pc via microsoft active sync and runs memory map perfectly.  Can someone advise on how to install Sky Angel In flight.  I have to say I'm very impressed with SA Plan - outstanding functionality!Smile  Rgds AMO
Posts: 8.2K, Visits: 9.6K
Installation guide at the URL below.
http://fly.styli.sh/inflight/installguide.aspx
RichardP
RichardP
Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)
Posts: 7, Visits: 19
Another apsect of the installer is what PDA devices are currently tested.
I use a iPaq rx3715 with Windows Mobile 2003 SE (Version 4.21) and although Windows Mobile 2005 is required, it would really be nice for the older ones to work too. (its a shame to let it die BigGrin
Richard P
RichardP
RichardP
Richard P
I do know that there are several people using SkyAngel InFlight on Windows CE 4.2 devices, so it must be possible.
RichardP
RichardP
The Windows Mobile .CAB gives an error 'This is not Windows Mobile Application' and the CE version gives an application load error - I will post the exact error if it helps (looks like a .NET error) BigGrin
Richard P
RichardP
RichardP
RichardP (11/6/2009)
Richard P
The Exact error is 'Skyangel.exe TypeLoadException'
This is something that a couple of people have reported, but the majority of people don't seem to have a problem. So far I haven't been able to work out why the software has stopped working on this small number of devices; there doesn't seem to be a common factor.
What version of Windows CE is it running?
