Flightplan route waypoints
srayne
srayne
Posts: 388, Visits: 8.3K
lhe (07/02/2014)I've never understood why DCT is required. There can be no ambiguity if you omit it and there would be less to write...
An IFR route would normally be a list of significant points separated by ATS route designators, the DCT is use to replace the route designator where there is none (as in a VFR flight) this makes parsing easier.
Edited 2/7/2014 2:31:57 PM by srayne
lhe
lhe
Posts: 154, Visits: 445
The added difficulty of parsing a route description without DCT would be negligible. (At least as long as it is impossible for an ATS route and a significant point to have the same designator.)
Posts: 8.1K, Visits: 9.3K
I think we may have a potential solution to this, where some VRPs are left with their identifiers intact when generating a flightplan. Specifically just those which HAVE identifiers. Could somebody give me a few example flightplans where there are VRPs which should be left intact according to local rules?
Here is the excerpt from Austro Control regarding specification of flight routes in a flightplan (translated from German):
For those parts of the route which lie inside FIR WIEN, only ATS routes, pre-defined routes and 3 or 5 letter identifiers as specified in the AIP are allowed to be used in field 15 as enroute points.
This means quite specifically, that geo coordinates are not accepted.
If SD already maintains a list of reporting points and knows where they come from (either AIP or not) then use that information. Otherwise I would use names that either are 3 or 5 letters long verbatim in the flight plan. All others still as geo coordinates.
Can you give an example of some VRPs in Austria which meet that specification?
I'm quite sure coordinates must be allowed, as not every route has turning points which coincide with defined waypoints. Especially routes along valleys etc.
For example the points STEIN, PESAT and SASAL. They are coordination points on the border between Austria and Hungary and frequently used as border crossing points.
Those are not VRPs and would never have been converted to coordinates in the flightplan route field.
Edited 3/21/2014 10:23:30 AM by Tim Dawson
bharb
bharb
Posts: 26, Visits: 351
Just a two examples of what has been accepted in Austria on my last flights:
OEAES LOAD 1315-LOAS
LOAU LOAG
(DOF/131002)
N0100VFR GRAFENEGG STO KREUZENSTEIN KL DT FR SC PE
OEAES LOWL 1050-LOAD
LOAG
(DOF/140311)
N0105VFR K PLESCHINGERSEE TRAGWEIN GREIN LOLG MELK
In the last plan you can see there are published VRPs (K), Lakes (Pleschingersee), Villages (Grein) and even airfields (lolg) in it - and accepted without any notice!
Once again, please rethink that as an option,
Bernhard.
Thanks, it's only VRPs we are working with at the moment however. Where is the VRP "K" you mentioned in your last post please?
(This highlights the issue really. If I don't know where it is, how is the controller supposed to know?)
bharb
bharb
Great news, thanks in advance. K is in the north of Linz (LOWL) at danube river.
Cheers
