Chart Access Error on SD IOS IPAD 3.0.5
w5400
w5400
Posts: 18, Visits: 102
Hi Team
as of this morning I'm getting the ...Failed to read past end of stream..... error message when accessing the Chart Menu under Setup. Any ideas?
Victor
It sounds like a partial or corrupt download is present on your device. How much happens before you get that error? Does the Charts window come up at all? Perhaps you could post a screenshot, as that would be most illuminating.
w5400
w5400
Tim, thanks for your speedy response. Without having changed any settings chart access functioned properly later that day. Still wondering what caused that glitch.
One small issue regarding Swiss alpine VFR routes. Routes 72 and 83 are not depicted on the chart (last cycle and current cycle).
Still fascinated by your outstanding aviation software.
Victor
Are you sure? I think they're all there. Check your map clipping settings; just like airspace, SkyDemon hides routes whose lower boundaries are higher than 4000 feet by default. If you plan higher, or fly higher, or change the settings, they will appear.
w5400
w5400
Apologies, Tim, you are, of course, right, those missing routes were just hidden.
Victor
w5400
w5400
Tim the error mentioned in my first post is recurrent, please regard the attachment. Meanwhile a second error message has cropped up. Can you please look into this.
IOS 7.0.6
SD 3.0.5
Thanks Victor
Both of those errors indicate a problem with your internet connection which is preventing SkyDemon from obtaining the list of charts. There isn't anything we can do about this from our end.
w5400
w5400
Thanks for trying....must be a WIFI connectivity issue as there is no similar problem on windows PC via cable DSL.
