Czech (LKAA) chart errors
Thank you for pointing out these errors in our Czech Republic chart. We have begun an investigation into how they occurred but in the meantime have fixed them and published a new chart for all users.
Quit
Quit
Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)Too Much Forum (484 reputation)
Posts: 4, Visits: 16
Hallo,
found map errors:
1) There is again wrong part of TMA LKMT, exactly the same as in my first message:
Wrong shape of TMA LKMT - circle part of TMA around VOR/DME OTA is only sector - in clockwise direction approx from radial 183 to radial 283 VOR OTA. Remaining part of circle is wrong and should be deleted as well as its wrong vertical borders (4500ft to FL125).
2) There is wrong remain from old shape of TMA Brno which should be deleted, I don't know how to better decribe the area than by approx coordinates, so they are (starting the most western and going clockwise):
N491826.60 E0170307.15
N492746.45 E0172831.15
N492158.65 E0174924.70
N491445.20 E0173450.05
I hope it will be useful
I mixed up my previous reply; it was the second issue that had already been picked up as an error. The first was an amendment we missed.
Thanks for the information about the frequency, I have forwarded this to the person responsible.
Quit
Quit
I would say - second issue was caused by wrong decoding of definition Air Traffic Services Airspace from AIP CR because there was not such an circle TMA for at least 10 years.
Wrong freqency:
LKCM airfield info wrong freqeuncy of Brno Turany ATIS 132,450 should be corrected to 131,1
Edited 1/10/2014 10:25:33 AM by Quit
Thank you. The first issue was actually picked up internally prior to today's chart update. The second issue we missed, and we will investigate how that change was missed in our regular chart update cycle.
A new Czech Republic chart has now been published with both issues resolved.
Quit
Quit
I have found errors in LKAA airspace map:
1) CTR LKPO has been withdrawn (at least since October 2013)
2) Wrong shape of TMA LKMT - circle part of TMA around VOR/DME OTA is only sector - in clockwise direction approx from radial 183 to radial 283 VOR OTA. Remaining part of circle is wrong and should be deleted as well as its wrong vertical borders (4500ft to FL125).
Tags
