SkyDemon Flight Planning
AIP Plates N/A In Offline Mode
ComJam
ComJam
posted 12/6/2013 10:24:16 PM
Visits: 63
Morning y'all...
I recently encountered some problem with the AIP feature on the PC version.
When I'm planning a flight in offline mode, the "Airfield Plate" box on the right is empty. It doesn't load a single plate by itself, even when I'm trying to look up a specific airport.
I have downloaded all plates (National AIP + DFS subscription) to my PC, it only works as long as there is an internet connection, then all plates are in the box, green lit with those "already downloaded" arrows...
From what I understand it says in the Help Section, that all those downloaded plates should be there, when going offline!? Or does this only apply to mobile devices?
Background : I'm using SkyDemon regularly offline for planning (and old-school printing charts... ) since some of the schools I instruct with do not provide internet access at the dorms or briefing rooms.
Someone's got an idea??
And my SkyDemon is # 3.0.2.0
cheers,
CJ
Edited
12/6/2013 10:27:02 PM by
ComJam
posted 12/10/2013 5:05:12 PM
Posts: 8.2K,
Visits: 9.7K
Can you give us steps to reproduce this, please? This sounds like a bug that was fixed a few versions ago.
mbr
m
mbr
posted 10/1/2018 8:23:06 AM
m
Visits: 8
A very old thread, but the problem still exists: I loaded the German AIP (in total) and then switched WLAN off on my iPad mini 2.
During planning a flight or during flight and planning a new destination the approach chart of the airfield (not all) will not be displayed
with
the message: "Um diese Funktion nutzen zu können, muss eine aktive Verbindung zum Internet bestehen..."
or in my translation "To use this function there must be an active Internet Connection exists. ...."
Is this bug this existing or has come up again or do I make something wrong. Internet connection switching on (during flight) is not possible since I have currently no active sim card in my iPad.
Thanks in advance for a helpful answer.
Bernhard
posted 10/1/2018 10:52:28 AM
Posts: 8.2K,
Visits: 9.7K
Please contact technical support who will help you determine what is wrong. They can talk you through it on the telephone if necessary.
