Flight plan data / PBN
Cobalt
Cobalt
Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)Too Much Forum (118 reputation)
Posts: 1, Visits: 3
Hi - newbie user here trying to get first flight plan into SkyDemon.
Simple question - how do I specify in the aircraft profile the required PBN/ entry for the "performance based navigation"? I want to add PBN/B2 for B-RNAV approval, but there is no such thing as RNP5 or B-RNAV in the list of equipment to select, and if I specify PBN/B2 in the bottom "other equipment" box, the flight plan contains COM/PBN/B2, which is not as intended...
I am sure this is just as simple thing and I am embarrassed that I am not able to find it.
Any quick tips? (of course I can always manually edit the FPL before filing)
[Skydemon 3.0.1 / iPad and PC]
Posts: 8.1K, Visits: 9.3K
I'm afraid there is no "short cut" in SkyDemon for specifying PBNs. You will just need to add the PBN/ entry in the relevant box yourself before submitting the flightplan.
Awful Charlie
Awful Charlie
Posts: 21, Visits: 269
There seems to be a workaround to this - in the 'Aircraft equipment editor' specify 'Additional Equipment (not in this list)' option, and add to the 'Other Nav Equipment' your string - with "SBAS PBN/B2D2S1" it seems to appear ok in the FPL
I'm pleased to report that a forthcoming version of SkyDemon will have built-in support for specifying your aircraft's PBN level.
