Planning a Fuel Stop
Scottintexas
Scottintexas
Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)Too Much Forum (672 reputation)
Posts: 5, Visits: 19
I am trying out this software and using the opportunity to plan a flight. The length of flight is beyond fuel capacity and the program, rightly, tells me so. However, I cannot figure out how to set one of the points to a fuel stop. The radar picture just shows the same altitude. A fuel stop is going to take some time as well.
I have searched the forum and was unable to find the info. If it is there then my search criteria was bad.
Using Trial version 3.0.1.0
There is no way to plan a fuel stop along a route. Currently SD does not offer the possibility to plan "stop over" points. The request for it has been made a few times already; if you search the forum you'll find it.
I wonder if Tim can't be convinced that this is a useful addition. I, certainly, would love to have it!!!
Bouwair
Bouwair
Posts: 39, Visits: 2.8K
Your searching was OK, there is no possibility to add a fuel stop.
I hope that Tim will consider this possibility.
We are planning a trip from the Netherlands to Croatia and we will need a lot of fuel stops.
In those cases it would be very handy to plan the complete trip with fuel stops.
with kind regards
Bouwair
For the time being, you simply need to plan your trip as two routes.
adhawkins
adhawkins
Posts: 274, Visits: 2.5K
Tim Dawson (04/11/2013)
For the time being...
Oooh...sounds (potentially) interesting Smile
Andy
Scottintexas
Scottintexas
Thank you all for your responses. I take it this software is not being used much in the United States. I like the available features, but there are a lot of features that would make it "brilliant" as the English would say. Fuel stops is one of those.
Yes, frankly, I have to agree. Although not a major issue it is a small, little feature I miss. The scenario is thus: I plan a long trip and break it up into individual routes which I enter and save in SD. Then, for various reasons, I land earlier or later and fuel up at this different landing point. Now all my other routes are off because of this. It's a bit of a hassle to fix the other routes to take that alteration into account.
No biggie but certainly would be appreciated.
Aha, but that is definitely a feature above and beyond simply being able to have multiple sectors in one trip. Now you want fuel usage (and therefore weight and balance) to automatically flow through to subsequent sectors, which will entail a necessarily tricky user interface to manage and set up. All this user interface would need to simply not exist for that majority of customers who have no desire for such multi-sector planning.
SkyDemon has technically been able to support multiple sectors per trip for years, it just doesn't allow you to create them. You can alter the raw XML of a file to put several sectors into it and then load it, but nothing fancy will happen with regards to fuel and weight and balance.
G-OIBM
G-OIBM
Posts: 71, Visits: 946
C'mon Tim,
I raised this as suggestion about a year ago and lots of posts were received supporting this feature.
Its come up again - so any chance of popping this facility into SD?
Hugh
Hugh
G-OIBM
Commander 114
Tim, what I envision is a somewhat less restrictive paradigm of what constitutes a waypoint. As a user I would want to be able to specify three additional items of information for each intermediary waypoint:
1) Whether the waypoint is used for a "stop over".
2) If so, how long the stop over delay is going to be, and
3) what the amount of fuel is when leaving this waypoint.
I don't think that this would require much in the way of changes to the user interface. Currently (on the iPad), when I "long press" on an intermediary waypoint a window opens giving me the options (among others) to either remove the waypoint or get more information about it. Choosing the latter, I am presented with the following possibilities under the Route heading: "Start New Route", "Append To Route" or "Insert Between Waypoints". A new option titled "Stop Over Here" could then take me to a window where I could enter the stop over delay and new fuel load.
On the vertical view this stop over point would automatically lead to a "crossing" altitude equal to the field elevation. The stop over delay would be included in all ETA calculations and, of course, also show up on the PLOG. And the fuel/range/endurance calculations would need to take the new fuel situation into account. I could also see a stop over point being a different color in the map view. And for the fuel calculation I would add the standard values for Taxi/Takeoff, Landing and Holding Time fuel requirements.
What do you think?
Edited 11/8/2013 9:20:14 AM by ckurz7000
