SkyDemon Flight Planning
re install no internet connection
Gonk
Gonk
posted 9/28/2013 9:20:54 PM
Visits: 66
Hi Firstly this has happened before!
Had to do a reinstall of demon, once done I am not able to access the net to download anything or access the sky demon server.
I remember the last time this happened I was advised to delete a particular file, and after doing this the programme worked fine.
I have an internet connection, demon is on line, anyone know where to go next?
Cheers
Neil.
posted 9/30/2013 3:39:16 PM
Posts: 8.2K,
Visits: 9.7K
I don't think SkyDemon has broken your internet connection.
What exactly do you see when you try to work SkyDemon?
Gonk
Gonk
posted 10/4/2013 2:01:47 PM
Visits: 66
I've sorted it, Demon completely stopped working when I uploaded the latest version onto my pc.
I uninstalled it and downloaded again, but it would not connect to my router, or maybe your server, this situation has happened before in a previous version.
It took me ages, (my personal internal memory is only running at half speed at my age), but I finally remembered that I had been advised to go into the demon documents and manually delete the skdl file and then re-log in with log in and password.
After doing this all is well back to normal.
Working fine, I assume that the prog creates this file and if one already exists it can't recreate and therefor (in my case) disables the sever.
Its running fine now.
Just may be a point to note.
A great programme, i recently used it for all my planning from:
Tatenhill to La Rochelle.
La Rochelle to Ampuriabrava.
Ampuriabrave to Avignon
Avignon to Amiens
and then the trip back Amiens to Tatenhill.
It worked a treat in every respect ,notams, weather, danger areas..........route etc.
Well done "respect".
Cheers
Neil.
