Feature Requests - Checklists + Bigger Buttons
neiloakley
neiloakley
Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)Too Much Forum (702 reputation)
Posts: 6, Visits: 14
Hi Tim
Yesterday i spent a few hours playing with PocketFMS and Skydemon on a 7" tablet PC running Windoes Embedded R3
I like both apps, but the maps on SkyDemon are superior as if you zoom in on PocketFMS to anything less than 6nm, the font and graphics appear blocky (like its an enlarged bitmap instead of vertor based)
However, there are features on PocketFMS i would love to see on SkyDemon (i'm still undecided which one to purchase so if these bits get added the choice will be clear)
1) Bigger buttons - on the 7" screen, the menu is barly 5mm tall and makes it difficult to select accurately using my finger in flight. I'm also prone to loosing the stylus. If all buttons were slightly larger, perhaps transparent and hidable it would be SO much easier to use in turbulent air. Example, when pocket FMS loads up, the buttons to accept or not accept the disclaimer cover one third of the screen. On Sky demon its barely 5mm by 20mm.
2) Checklists - PocketFMS give you rudamentary checklist options. But they have to be customised and integrated by the user. I'd love to see checklists in Skydemon, that can me easily modified (maybe from preset templates by aircraft) and sync's with the tablet PC. The checklist should then be easily accesible from the main menu when in flight (and again transparent so the map is always in site if needed)
What are the chances?
Many Thanks
Neil
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Sure - I understand that and it makes perfect sense. It's probably best if I send you some screen shots.
I'll try and explain it though.
Imagine you have a runway showing on the screen (at the default DPI settings) - the text is sized to fit more or less exactly within the runway - so you have the length in the middle and the runway numbers at either end.
If you then double the size of that text, you can no longer see it as it obliterates the underlying runway and all the text draws on top of itself. The runway text itself needs to be excluded from the global scaling if possible.
This is the contents of my XML file:-
Steve
neiloakley - 6/16/2010 10:21:06 AM
Tim Dawson - 6/17/2010 10:13:53 PM
G2 - 8/12/2010 12:37:18 AM
churchy - 7/6/2012 8:08:08 AM
sprucegoose - 8/31/2012 11:53:24 PM
Richard Avery - 6/19/2010 9:00:10 PM
neiloakley - 6/20/2010 5:26:03 AM
Richard Avery - 6/20/2010 11:32:53 AM
Tim Dawson - 8/12/2010 9:02:00 AM
G2 - 8/12/2010 2:35:25 PM
stevelup - 8/26/2010 8:03:07 PM
Tim Dawson - 8/27/2010 9:59:18 AM
stevelup - 8/27/2010 11:41:47 AM
stevelup - 8/27/2010 11:46:51 AM
stevelup - 8/27/2010 11:48:15 AM
Tim Dawson - 8/27/2010 12:23:01 PM
stevelup - 8/27/2010 3:07:13 PM
stevelup - 8/29/2010 11:51:55 AM
Tim Dawson - 8/30/2010 10:27:14 AM
stevelup - 9/3/2010 7:41:32 AM
