Updating App loses Pooley and AFE Plates
If you contact our support and identify yourself, we can work out why your AFE plates are no longer showing. Are you sure it isn't the case that your AFE purchase was for the 2012 plates, which have now been deleted? It is unlikely that an upgrade would affect plate availability.
nje
nje
Posts: 384, Visits: 4.2K
sorry, I was reading it on my phone, missed that bit. Good luck
TheHoff
TheHoff
Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)Too Much Forum (656 reputation)
Posts: 7, Visits: 24
Yep. I mentioned it in my post above. Smile
nje
nje
Have you tried logging out of skydemon and then logging back in again, this usually resolves this type of problem
TheHoff
TheHoff
I have a similar problem.
I upgraded to 2.7.0.0 as per instructions (uninstall though control panel, then download and install). after that I'd lost my AFE subscription. It still has a month to run.
I've tried logging out and back in but it says I need to purchase the plates.
Anyone have a fix for this?
Mark
Upgrading does not wipe out downloaded plates. The only way this could happen would be if you deleted the app, then installed the newer version.
jay_hl
jay_hl
Posts: 7, Visits: 75
Hi All
I have just update to the latest software version (2.7 from memory) for SD for iPad, and noticed that in doing so my previously downloaded entire Pooleys and AFE plates needed downloading again.
Is this a bug that when the software updates all the pdfs are lost, and if so, I can imagine that re loaded any custom pdf in the new document library might be a pain to re load.
Just sat through 80mb (Pooleys) + 155mb (AFE) to downloads, and don't fancy doing this every software version update.
Jay
