Wrong names in frequency list next to LOWL
bharb
bharb
Posts: 26, Visits: 351
Hello!
Next to LOWL (Linz Airport in Austria) there are two smaller airports (LOLW and LOLH). After planning a route to each of the smaller ones I noticed that in the frequency list of the PLOG the name for Linz Tower ( LOLW Tower ) or Approach is wrong. LOLW gets replaced by the smaller airports ICAO, like LOLH Tower. The Frequency afterwards is correct.
Can you have a look at that?
Thanks,
Bernhard.
Admin
Admin
Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)
Group: Administrators
Posts: 48, Visits: 212
I will speak to the person responsible and see whether the LOWL frequencies can easily be removed from those two smaller airfields.
bharb
bharb
Thanks for the response. But the frequency should not get removed because it is important there, but maybe there is something wrong with the algorithm behind because in other cases the same frequency is labeled correctly.
Cheers,
Bernhard.
