How to remove unwanted routes?
DirDej
DirDej
Posts: 120, Visits: 1.5K
I can create, open, save, save as, save to cloud but how can I remove or delete routes from within SD?
Thanks,
Dirk
Steve Turnbull
Steve Turnbull
Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)Too Much Forum (952 reputation)
Posts: 5, Visits: 20
Hi Dirk,
What platform are you using Skydemon on?
On the iPad, you select Route, Open, then when you can see the full list of routes, just swipe to the right on the one you want to delete and a Delete button will become available.
Steve
DirDej
DirDej
No such luck on Android.
Dirk
srayne
srayne
Posts: 388, Visits: 8.3K
Andriod is similar to iPad, Select "Route" then "Open", press and hold on the route name you want to remove and a "Delete" button will appear.
DirDej
DirDej
Found it, thanks
