PC version - removing downloaded plates?
Liam Sandie
Liam Sandie
Posts: 72, Visits: 261
Once you have finished viewing downloaded plates how do you remove them from your PC please?
https://www.instagram.com/liam548/
Admin
Admin
Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)
Group: Administrators
Posts: 48, Visits: 212
There is currently no option to delete cached plates from an installation of SkyDemon Plan.
genefilter
genefilter
Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)
Posts: 5, Visits: 51
You can delete the Plates directory which will be rebuilt the next time you run SkyDemon, its not supported, but I've tested it on mine and it does work
You can find the directory under:
C:\Users\<your username>\AppData\Roaming\Divelements Limited\SkyDemon Plan\
I'm guessing the software must check the versions of the files such that when they are updated at source, they are updated ?
Liam Sandie
Liam Sandie
I hope so although probably not worth the pooleys plates add they just get released as one unit
