Sky Demon and Galaxy Tab 7.7
guille
guille
Posts: 149, Visits: 2.4K
I tested yesterday SD on the GT 7.7 flying and just afterwards I decided to buy SD. It is really great ! Anyway, I want to make two (only two!) suggestions and ask also some questions.
Suggestions :
1 - Could it be possible to parametrize the size of the menus ? With the high definition of my device, it is a bit difficult to read. As it is possible to do this with the font sizes for the map, I imagine it could be done for the menus.
2 - When we open the log after flying, there is a good synthesis of the flight. Could it be possible to save it in a simple text file ? I didn't found the way to do this.
Questions :
1 - How is calculated the wind ? Does it come from the nearest airfield METAR ? Or is it the difference between the cruise speed of the aircraft (as declared) and the ground speed ?
2 - I imagine that the dynamic approach will be soon implemented in the Android version. When are you going to do so, if it is the case ?
Thanks in advance for your answers
