Visits: 3.2K
Quite apart from the hassle of keeping separate aircraft definitions in sync if things change (e.g. aircraft re-weigh), it wouldn't quite work as the category can change during the flight due to fuel-burn. Indeed, where the max-landing weight is less than MTOW, it pretty much HAS to change! What I was hoping for is to enter the passenger and fuel loads and then be able to quickly check whether I'm within the aerobatic category (or at what point along the flight I will enter the aerobatic limits) and can safely do a loop or two en-route.
