French VAC plates not up to date
Clive
Clive
Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)
Posts: 12, Visits: 13
Hi I just registered and updated SkyDemon and opened the VAC for Les Sables d'Olonne (LFOO) and found that it is not the latest version.
The plate was updated in March with a frequency change which is kind of important.
I know that the web links on the SIA website change every 4 weeks, so I wonder if you are using the right ones....?
Cheers for a great product.
Gentreau.
Clive
Clive
No reply or acknowledgement, but I see the plate is now up to date.
Thanks.
There was a delay of a few days last AIRAC cycle as our software had become disconnected from the Eurocontrol system that feeds it, but this has been corrected now. This only applies to the AIRAC dated 2 May though, it doesn't explain why an earlier update was not picked up, unless the plate had not been published by the French onto the Eurocontrol EAD system properly.
