FRANCE CHART UNUSABLE
ahillyer
ahillyer
Posts: 15, Visits: 571
i just updated the french chart, and in the SE of France there is no data whatsoever, only a huge red cross.
Skydemon is currently unusable, please can this be rectified ASAP.
thanks,
Andy.
This is happening because the latest chart is not compatible with the (older) version of SkyDemon you are using.
We have now published a replacement chart which is compatible with older versions, so you should either be able to update your charts again or update your SkyDemon to the latest version, either will work.
ahillyer
ahillyer
I had upgraded Skydemon to version 2.6.0 before the upgrade to the chart.
I have just updated the chart again, and it's still not working. It's only in the SE of France on the coast which is not working, when I scroll round the rest of France it's OK. Could it be to do with my 'home' airfield, or user waypoints ?
cheers,
andy.
Edited 4/5/2013 8:03:47 AM by ahillyer
Hmm, perhaps it is the chart style you are using that is not compatible with the new routes we created in that area. Could you try switching to an alternative chart style and let us know if that helps?
ahillyer
ahillyer
Yes, looks like that's the problem.
It works with; Skydemon charts, US FAA, Skydemon Charts 2 and Italian Avioportolano.
It does not work with the rest. I usually use French SIA or German DFS.
All charts are OK if I turn off the 'Mapping -> Routes -> VFR routes' option.
cheers,
Andy.
Edited 4/5/2013 2:20:57 PM by ahillyer
Thanks Andy. We've removed the VFR routes until the next AIRAC update, by which time the software will have been updated so that all chart styles are compatible.
