Weight & balance cessna 150 problem
Jerome
Jerome
Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)Too Much Forum (250 reputation)
Posts: 1, Visits: 15
I am new here and still trying the trial version.
I am struggling with the weight and balance calculation in skydemon hope someone can help me.
I have the following w&b data for the cessna 150
Empty mass 1175 lbs - arm 32,5" --> moment 38,18
Pilot + Passenger 320 lbs - arm 39" --> moment 12,48
Fuel 9 usg = 54 lbs 54 lbs - arm 40" ---> moment 2,16
totals: 1549 lbs moment: 52,82
When I input these data in aircraft properties skydemon says 1548,9 lbs (this is correct) and moment arm is 34,10 not correct.
What am I doing wrong?
regards
T67M
T67M
Posts: 206, Visits: 3.2K
Skydemon is trying to help you, but appears to have confused you slightly. 34.10 is the arm (in inches) not the moment (in inch-lbs). Moment divided by mass equals arm, 52820 / 1549 = 34.10. You may also be confusing commas for thousand separators with commas for decimal points.
Hope that helps,
T67M
