Retrieve Log from Connected Device - value results in an un-representable DateTime
Fibreman
Fibreman
Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)Too Much Forum (451 reputation)
Posts: 2, Visits: 129
Have a similar issue re Stuart's post Sync with Garmin Map96 with a Garmin 296.
Retrieving log to Garmin's Flightbook (version 2.5.1) works fine.
Any (positive Smile) suggestions gratefully received.
Thanking you in anticipation.
First retrieval attempt: -
System.ArgumentOutOfRangeException: The added or subtracted value results in an un-representable DateTime.
Parameter name: t
at System.DateTime.op_Addition(DateTime d, TimeSpan t)
at Divelements.SkyDemon.Analysis.xd75bb219d46ac4c4.xce3a57149e07a4f3()
at Divelements.SkyDemon.Analysis.xd75bb219d46ac4c4.x340c43addd945fd2()
at Divelements.SkyDemon.Analysis.xf5f8bc61a3435706.GetCellValue(GridColumn column)
at Divelements.SandGrid.GridRow.DrawCells(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats)
at Divelements.SandGrid.GridRow.DrawRowForeground(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats)
at Divelements.SandGrid.InnerGrid.x14295bd0cde2ff5d(RenderingContext x0f7b23d1c393aed9, Boolean x48d1c33294a7dd40)
at Divelements.SandGrid.InnerGrid.x7f63857195e5d213(RenderingContext x0f7b23d1c393aed9)
at Divelements.SandGrid.SandGridBase.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at Divelements.SandGrid.SandGridBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Second retrieval attempt: -
http://www.skydemon.aero/forums/Uploads/Images/1680a815-8daa-44f8-87ee-1deb.png
Edited 03Mar2013 19.29 to correct link to Stuart's post
Edited 3/3/2013 7:32:58 PM by Fibreman
