Lost waypoints
SeanKx
SeanKx
Posts: 48, Visits: 936
I've just downloaded the latest version and notice that my waypoints have disappeared. Also some of the information on the pc map does not transfer to the device. Namely my home field Darley Moor which is named on the map just transfers as a notification ring depicting the zone?
I have just bought a 7" device to try and have loaded SD from my old device with the above showing. When I sync they vanish.
Any ideas please?
Thanks..
Sean Kx
Samsung Galaxy Tab A7 Lite
Android 13
Skydemon latest version always
ahillyer
ahillyer
Posts: 15, Visits: 571
Yes, same thing happend to mine after the latest chart update. If you've saved the waypoints to the 'cloud' you can retrieve them that way, otherwise the're gone !!
cheers,
Andy.
SeanKx
SeanKx
Looks like they're gone then. On the issue of the map, does/should the map on the GPS device exactly replicate what is on the pc??
Sean Kx
Android 13
Edited 2/10/2013 9:05:28 AM by SeanKx
Posts: 8.1K, Visits: 9.3K
Custom data that you have created is not transferred to your device; this is a manual operation if you want to do it. There are some instructions in our online documentation for transferring custom aeronautical data to an iPad or another device.
