Cessna 172SP, NAV III (Garmin 1000 with KAP140)
Dreha
Dreha
Posts: 13, Visits: 77
Hello to everyone,
new to this Forum I´d like to add an aircraft to the library. I will continue to check the W&B and Fuel Calculations with Jepp FliteStar which has a rather sophisticated (and complicating to feed) calculation system. First returns concerning local flights are quite similar, give or take SD more on the conservative side. Descent fuel is higher than with FS.
Best wishes from LOIH
Harald
PS: Anyone interested in a Robin CDI135 (Thielert Diesel)? In FS one had to use the "Jet-Mode" to model it`s FADEC.
PPS: SORRY! I can only save the aircraft in the Cloud but not local. Any idea how to upload?
Edited 2/3/2013 2:44:20 PM by Dreha
Dreha
Dreha
now that should do the trick ;-)
C172SP NAV III D_EPME.aircraft (998 views, 2.00 KB)
