SkyDemon Flight Planning
ipad vga port
ipad vga port
ipad vga port
pink leader
pink leader
posted 12/10/2012 8:13:28 AM
Visits: 2K
Steve
You are right - am on ipad1. Will ensure someone comes with an ipad2.
Cheers
D
posted 12/10/2012 7:52:33 AM
Visits: 4.9K
I'm guessing you're using an iPad 1? In which case you're out of luck. The SD team would need to write a whole load of extra code to support Video Out via VGA. The original premise of the Video Out functionality was that the UI would be on the device and the content on the display.
If you'e using an iPad 2 or later, then you can just enable video mirroring and it will work fine.
pink leader
pink leader
posted 12/7/2012 12:40:11 PM
Visits: 2K
Have just received an ipad vga adapter and connected Skydemon on ipad to a projector. However, it seems SD does not support VGA out on the ipad. Any chance of an update to support it or does anyone know a workaround. Got a session on Dec 11 when this function wd be very useful indeed.
David
