Weight and balance coordinates
MikeF
MikeF
Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)Too Much Forum (391 reputation)
Posts: 3, Visits: 9
Hi I'm new to skydemon and using it on an ipad.
How do I go about changing the default w&b graph coordinates to my specific a/c?
I've tried inputting them in the same format as the default but the line goes pink and the default graph doesn't change.
sorry if this has already been covered.
Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)
Make sure you adhere to the proper format: Arm1, Weight1; Arm2, Weight2; ...
Be sure to separate arm/weight pairs by semicolons and each arm from its corresponding weight by a comma.
MikeF
MikeF
Posts: 3, Visits: 9
Thanks Chris
i'll try that didn't see any semicolons between the pairs but it makes sense.
cheers
Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)
Posts: 593, Visits: 4.9K
I've always used all commas every time I've done it.
Maybe it has to do with international number formats? Over here in Austria we use commas as decimal separators whereas the Anglo-Saxon realm uses dots.
