VFR Corridors on Benelux map
MrReallySerious
MrReallySerious
Posts: 14, Visits: 417
The VFR corridors for the Dutch Wadden Isles are not on the Skydemon map. Is there a way to addd those to the map? The Dutch airspace at the Waddenzee is classed as A from 1200ft up, but the VFR corridors should be used at a minimum of 1500 ft (when cloudbases allow) for enivronmental reasons. So VFR corridors to Ameland and Texel are available.
Rob Hart
Rob Hart
SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)
Posts: 77, Visits: 454
I will take a look at this. Hopefully it will be a relatively easy procedure to add these corridors and Tim has been working on a tool which should make it very easy for us.
MrReallySerious
MrReallySerious
Thank you for the update. Waiting for the new version!
