Visits: 20
As Steve says, the problem was resolved by changing Parallels to use Bridged network connection. Further investigation suggests that it was less a clash between firewalls but rather an issue with VirusBarrier on the Mac. I haven't got to the bottom of it and don't need to bother anyway since SD now works as expected.
I did use the web based version for a while but found it difficult to get the fonts up to an easily readable size. I could have pursued that avenue but since I wanted to run Plan and Nav on the iPad I got the full licence and prefer using the native version even if it does run only on Win systems. I suspect that the fonts were a manifestation of the same VirusBarrier blockage but, again, don't really have time to sort it out when I've (now, and thanks to Steve) got the native version working properly.
