Loading flight plan onto SD card
G1000 pupil
G1000 pupil
Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)Too Much Forum (450 reputation)
Posts: 4, Visits: 47
Hello
This is my first post on the SD forum. I drive a G1000 which can receive a flight plan from an SD card. Can anybody please explain, in simple terms, having created a route in Skydemon, how do I put that route onto the SD card?
Thank you.
nje
nje
Posts: 384, Visits: 4.2K
This is how you would do it normally to transfer it to a device, I'm not sure if this is what you are after or not.
If you are using a PC with SD on it to create your route, then insert your card into a card reader and then go to 'Setup' > 'Device connectivity options' > 'Install Skydemon on a Windows CE device' > Choose the drive and click next. Everything including your route is now on your card.
G1000 pupil
G1000 pupil
nje (22/06/2012)
nje
Thanks for that. When you say "everything including your route is now on your card" will that then be OK to load into the G1000?
nje
nje
This is the bit I'm not sure about. What I've decribed is how to do it using a WinCE device, I have only just looked up what a G1000 is and so I doubt what I have told you is of any use to you, sorry about misleading you.
If you do a 'search' on the forum, I remember reading other posts about changing the file extensions so routes can be synced with Garmin devices
nje
nje
Have a look at this post, it mentions the G1000
http://www.skydemon.aero/forums/Topic3200.aspx
