Deleting old tracks
PB
PB
Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)
Posts: 6, Visits: 45
Is it possible to delete tracks from previous flights without deleting the logged data?
I'm afraid I don't understand the distinction you are making. The track log is just a file; no part of it can be removed without it becoming useless.
srayne
srayne
Posts: 388, Visits: 8.3K
PB (13/06/2012)
If you mean just remove the breadcrumb trail from the flight planning window then just close the flight log (vertical profile) window by clickin the 'X' in the top-right corner.
PB
PB
Tim
Sorry if I was not clear. I'm not much good with electronics (which is precisely whey Skydemon is so good for me).
After much button pushing, I worked it out. I needed to "Unload" my journey logs.
On that subject, the presentation of Log data appears to be much more useful on the Mobile device than it is on Plan. On the mobile device I get Take Off and Landing times, calculated duration and distance. On Plan I only get Take Off time. Am I missing something?
nje
nje
Posts: 384, Visits: 4.2K
Plan does give quite a bit of detil, but you are right it doesn't give takeoff and landing times.
In plan with the vitual radar screen showing - just look underneath the virtual radr and you will see
Total Distance- Total Time - Max Altitude- Max Speed.
From inside the Virtual Radar window, put the cursor on any part of the route flown and in the bottom left of your screen you will see:
Altitude - Speed - Elaapsed time flown - Route
I tried adding an image to show you but couldn't figure it out
PB
PB
Thanks nje.
For entering the logbooks I just open the flights in MD (hence having all the past routes on the screen at once). Aircraft logs from the device, pilot logbook from the PLOG.
It would be nice to get all the data from the Plan software, but far from essential.
Simples.
