running Skydemon mobile on netbook
hairgonejohn
hairgonejohn
Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)
Posts: 6, Visits: 6
I would like to try running Skydemon mobile on my netbook. Presumably I need an emulator to run CE on a pc. Does anyone have any recommendations please?
thanks
nje
nje
Posts: 384, Visits: 4.2K
No emulator required, it will work like the simulator does, you will just need an external bluetooth GPS unless your netbook is fitted with an internal one
. From Skydemon plan go to Setup > GPS Navigation options and setup your GPS. Then click on 'start GPS' in the top right of screen. You might also have to set up your netbook to connect by bluetooth first though.
hairgonejohn
hairgonejohn
Posts: 6, Visits: 6
thanks, I'll give it a go.
