TB10 Profile Wanted
BAT-21
BAT-21
Posts: 4, Visits: 71
Hi All
Does anyone have a profile for a TB10?
Thanks in advance
gaxor
gaxor
Posts: 16, Visits: 58
+1 if anyone has it please
KMCE
KMCE
Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)Too Much Forum (947 reputation)
Posts: 4, Visits: 26
Hello guys,
Here is a profile I did up for a TB-10 EI-BOE.
As before use at your own discretion.
The weights and balance are tricky to set up and any comments you may have on it would be appreciated.
Ken
Ken
TB10.aircraft (6.3K views, 1.00 KB)
BAT-21
BAT-21
Hi Ken
Thanks a lot, I don't think I could have sorted that out by myself.Smile
Andy
PBY
P
Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)Too Much Forum (189 reputation)
Posts: 1, Visits: 0
Hi Ken,
‌How did you arrive at your TB10 weight & balance flight envelope?
‌I've used the below coordinates which match the envelope in the Pilot's Operating Handbook (POH) but admittedly for some reason do not give a final result with the aircraft in balance.
‌49,613  80,972  92,1067  114,1151  120,1151  63,613
‌Regards,
‌Gareth
neilmurg
neilmurg
Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)
Posts: 43, Visits: 128
KMCE - 3/27/2012 7:52:19 PM
Hello guys,
Ken
KMCE, I take it your weight and balance chart uses kilograms and inches? Anyone wanting to use your profile, or use pounds and inches, or kg and cm will need to know that.
Did you derive the figures by analysing the weight/moment chart?
Good job though
R‌gds‌
n‌eilmurg
Edited 4/24/2017 5:55:34 PM by neilmurg
