Am I missing something here? New mapping engine beta
Posts: 593, Visits: 4.9K
Which, if you think about it, makes perfect sense as you are never deleting a leg, you are deleting a waypoint.
A leg is just the bit between two waypoints. If you were able to click on a leg and delete it, which waypoint would get deleted?
srayne
srayne
Posts: 388, Visits: 8.3K
pink leader (02/03/2012)
Right click on a waypoint and then click delete. Works Ok for me.
Forgot that one! Works that way for me too, but you can no longer select a route leg and press 'Del'.
pink leader
pink leader
Posts: 518, Visits: 2K
Am using latest version. Right click on a waypoint and then click delete. Works Ok for me.
D
srayne
srayne
I used to just click on a leg and hit Del. Doesn't work for me now!
Del doesn't seem to work any more (Tim - was this intended?) - you now have to drag the waypoint at the end of the unwanted leg and drop it onto the next or previous waypoint, or alternatively highlight the leg in the "route plan" window and press 'del' or click on the 'X' to delete it.
Edited 3/2/2012 4:45:04 PM by srayne
mr_rodge
mr_rodge
Posts: 22, Visits: 70
Hi there,
Should be something really simple I'm sure, I'm using Plan and since upgrading to the latest beta I can't delete a leg from a route for love nor money! Am I missing something? The only way is to create a new route and discard the whole flight planning to start again.
I used to just click on a leg and hit Del. Doesn't work for me now! I'm using Win XP.
Cheers.
