SkyDemon iPad version
David Johnstone
David Johnstone
Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)
Posts: 16, Visits: 602
I have been delighted with the iPad version.
However today it decided to tell me that I was using the non full version & shut down after 20 minutes.
How do I get this fixed as my current license is until July 2012 ?
David
0fficer
0fficer
Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)Too Much Forum (974 reputation)
Posts: 6, Visits: 94
Do you have the navigation upgrade?
wacits
wacits
Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)
Posts: 8, Visits: 42
I had the same problem today after about 30 minutes when the iPad wanted to go into sleep Mode. However after recovering it comes up with the error message and says you can use it after 10 minutes.
If you shut down the app and re-start it, it is good to go, however you will have to have saved your route and open it or create a new route.
How do you delete saved routes??
Still a good app, sometimes It seems to stutter. I have the 3G wifi 64gb version with latest os.
Any ideas on error message?
Wayne
Posts: 8.1K, Visits: 9.3K
You need the navigation upgrade for your subscription if you want to use SkyDemon for navigation as well as just for planning.
To delete routes, use the iPad standard way of sliding your finger across the route to reveal a delete button.
wacits
wacits
Tim
Thanks, have bought the nav upgrade and the slide delete works a treat.
Wayne
