Aircraft Profiles
PA28-140 Cheroke needed
markpodbery
markpodbery
posted 2/19/2012 11:25:19 AM
Visits: 42
Hi all,
Does anyone have the data for the above?
Mark
KMCE
KMCE
posted 3/1/2012 4:29:02 PM
Visits: 26
Hello Mark,
Attached please find the file I use - I have created it from POH and aircraft information.
I fly this aircraft on Mogas, so the file refers to this.
This works for my aircraft, and if you do decide to use it, you do so at your own risk.
You should verify that all data is suitable for your aircraft
Hope this helps.
Ken
Cherokee.aircraft
1.3K views,
1.00 KB
markpodbery
markpodbery
posted 3/7/2012 1:47:05 PM
Visits: 42
Thanks for this!
So I guess only the fuel side of things will be different then?
Many thanks
Mark
PS How do I download it as clicking on it does not work!?
KMCE
KMCE
posted 3/27/2012 7:57:10 PM
Visits: 26
Mark,
From recollection you need right click on the file and save it to ...\my documents\sky demon\aircraft. It will be then visible when you next start sky demon. When you select the aircraft tab, it should be there.
As to the mogas issue, this really does not have much impact on weights, but may be a little slower in the air as the 100LL would provide that little bit more power. You can update the data once it is in your aircraft tab, and change to suit you.
Hope that helps.
Ken
Ken
