SkyDemon and x-plane flight simulator (almost working)
appliko
appliko
Posts: 5, Visits: 22
It works.
mastubbs
mastubbs
Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)Too Much Forum (420 reputation)
Posts: 2, Visits: 9
Hi All,
Presumably there is no way to transfer xplane 10 on pc GPS data to skydemon on ipad by wifi yet?
Does GPS sim cable will work out of the box for xplane to skydemon on ipad?
Does anyone know if there is a cheaper alternative to GPS sim cable, hopefully one that uses USB!?
Thanks in advance for replies
Alexis Bretteville
Alexis Bretteville
Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)Too Much Forum (551 reputation)
Posts: 2, Visits: 21
Hi all,
any news about a future feature in skydemon which will take advantage of GPS data out from Xplane and then allow simulated training VFR flights before getting in the real thing.
Thks
gallwood
gallwood
Posts: 12, Visits: 47
What SkyDemon device was you using?
Do you know if it is possible to run the Windows version of the navigation SD app and connect it to X-Plane running on the same PC?
Graham
