1.1.1
Up and down
Up and down
Posts: 25, Visits: 1.9K
The additions to 1.1.1 seem fine. I wouldn't use Plan on a PC while flying, so can't comment on that, but the simulator mode is useful and fun.
I noticed that the simulated flights get stored as flight logs. I think it would be better if there was some way of distinguishing them from 'real' logs, or they simply weren't stored at all.
On a related note, I'm becoming quite a fan of keeping the logs as a record of past flights. Could there be a way of renaming or adding notes to the log file?
I agree that simulated flights shouldn't really be logged, but I'm not sure if we'll be able to make the distinction before the next version is released. We'll try.
The log files are stored in your My Documents\SkyDemon\Logs folder. You can change their filename by simply renaming them, but ensure you keep the long number intact as this tells SkyDemon the date of the flight. At some point in the future we will support adding notes and other bits of info to logs.
