Waypoints Wrong with Google Maps
nwhite007
nwhite007
Posts: 30, Visits: 293
Hi, I am sure I must be doing something wrong here, I am trying to add a few waypoints and pin point them accurately so have been looking up the coordinates longitude and latitude by going on Google maps, finding the waypoint in satellite format in this case my Grand Parents house and putting those into Skydemon, If i add them in this case from Google Maps its 50.764965 and 1.888635 it puts the waypoint near Frome? If I guess the the right area on the map SD shows the coordinates to be N504545.00 and W0015356.00 which is quite near EGHH Bournemouth Int Airport as it should be. Can some one enlighten me as to what I am doing wrong?
Many Thanks
revilla
revilla
Posts: 15, Visits: 29
What version of SkyDemon plan are you using? I raised the point on here a little while ago that the 2.2.1 version didn't allow you to enter decimal coordinates in the format produced by Google Maps (I was trying to do exactly what you are doing). Tim said this would be fixed, and I've just tried it in the laster Beta version (4th Nov Update) and entering the coordinates you have given seems to work fine, with the waypoint appearing just south west of Bournemouth airport as you say. If you want to make it work with earlier versions, I've written a little program which you can run in the background which monitors the clipboard and if it finds it contains coordinates in Google Maps format, it converts them to SkyDemon format, so with that running you can turn on the lat long marker tool in Google Maps, copy the coordinates, and paste them into SkyDemon and it all works! Bit of a bodge but it made life a lot easier for me before the feature was added Smile If you want me to send you a copy, let me know, send me a message.
nwhite007
nwhite007
Thanks for the reply, I am running the current version but not the new beta on test. Thats fine with me if you say it works in the new beta version I will wait until thats released. I can make do at the mo but will be just the job if it works in the new release, you know what its like most of my friends want to fly over their houses etc but we all live in Bournemouth control zone (Class D) so it will be much easier to find houses etc using SD mobile than trying to find their road then follow it. This way I can request orbits when spot on and keep it tight.
Thanks again and all the best
revilla
revilla
Glad to be of help. I have similar problems with friends in the Loughborough area - East Mids CTR.
