Fuel Figures by Mass
Ben
Ben
Posts: 32, Visits: 47
I know this was debated on the Flyer Forum, but I'd like to bring it up here too.
The M&B section includes the option to describe mass in terms of kg or lbs, but fuel figures are only available in litres and gallons. Could fuel flow options also include lbs and kgs please?
Posts: 8.2K, Visits: 9.5K
I don't understand this request. Fuel amounts are typically specified as a volume of liquid, and SkyAngel will calculate the weight from this and input it into W&B calculations automatically. Can you describe more about why you want to specify fuel amount in weight?
Ben
Ben
Aircraft with capacitance gauges and mass-flow meters have no need to think of fuel load in terms of volume. All of our company aircraft are calibrated in lbs (they're American after all), we effectively have no concept of volume. And why would you? Fuel is burned by mass, not volume. The volume of the fluid varies with temperature, so what you fill up with at the end of the day is not what you are left with the next morning! When we're refuelling, we do it watching the gauges so that we get the right mass of fuel on board, not volume.
I doubt any large piston or modern turbine aircraft consider fuel flow by volume - the quantities are so large that the errors would be huge - large aircraft talk about lbs, kgs... or tonnes of fuel!
I absolutely agree with you about large company aircraft. What I need to know, though, is how many VFR operating pilots want this feature compared to how many are happy with specifying fuel in volume. Responses on this thread will be an excellent indicator.
