Heading changing and map position jumping around erratically
GalaxyzA11+
G
Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)Too Much Forum (161 reputation)
Posts: 36, Visits: 2
Tim Dawson - 5/7/2026 11:33:18 AM
Since SkyDemon is very clearly not responsible for the location data being given to it by the operating system, I am struggling to understand what exactly you expect us to do about it.
Hello Tim,
I was exactly expecting a technical support in order to identifiy "why" this is appening and get a workarround.
More seriously, first I should open a new subject, because this one is not related to initial post, even if the trouble look's the same.
Since, I have worked arround and identified a couple of settings that may prevent the issue in android 16.
So far I'm not absolutely sure, so I can't give directions, apart this one :
  << dont buy Samsung devices with Android 16 if you expect to use GPS. They are currently Goggle-buged ! >>
What SkyDemon could do, would be to add a filter to the heading of the plane, It's changing to quickly. (short integration ?)
Best regards.
We will not be doing that, sorry. If a customer has a buggy GPS or device, it is not our job to try to cover that up, and I am not sure that it would be a helpful thing to do anyway.
GalaxyzA11+
G
Tim Dawson - 5/8/2026 9:15:40 AM
You didn’t get the point.
The filtering is not related to the bug. It’s just because the heading line has some kind of instability with SkyDemon in comparison of other Aviation navigation App running on the same device  at the same moment trought shared screen (i.e. Helios, SdvfrNext and VFRNav have a more stable/smooth heading than SD that is like a raw data)
This is not related to a bug, but in the way data are processed by the app.developer.
Second point, about the goggle "position" bug, you may have more Android customers affected in the future.
So far I just regret that you don’t advice your customers that (at least) Samsung devices with UI8.0 and Android 16 are not compatible with SkyDemon.
I paid 149€ and so far SkyDemon will not grant any refund.
Samsung is not in rest, I paid 399€ for this "new technology", and Samsung also claim’s ungulty. GPS is working,  no internal hardware failure.
Goggle said ?... we are the champions of innovation and merging technology !
Victims lose their money .
End of the story.
Today, I partially counteracted the issue.
I use SD as a moving map -only- and Helios as navigation tool, both on the same device with splitted screen.
A second device (different brand/manufacture/O.S.) is running VFRNav as navigation traking, and backup moving map in case of failure of the first device.
So far I'm good, but just disappointed that the most expensive one is the less reliable one since Android 16.
