No dat transfer from Safesky Avionix Aero Tracker to Skydemon
Reinhold
R
Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)
Posts: 4, Visits: 54
I just paired my new SafeSky Aero tracker device to my Safesky app (Premium) and further to the Skydemon app.
I have now a problem, when I start first the SafeSky app and the Aero Tracker device and then at last the Skydemon app on my Samsung tab A7 Lite.  By activating "Fly" use "Aero device(Aero1AA850)" , the SD-app shows " waiting for data " .  The Aero Tracker device/SafeSky-app  don´t send the data information to the SD-app.    But if I switch the Aero Tracker device  "off" and "on" again, the SafeSky system send than the data information to SD like as it should be.
Operate I something wrong or is my configuration of the tracker device maybe wrong.
Need here a little help at this issue.
By the way......, I also connect last week a bluetooth device to my KTR2 - Radio. This device works fine , but maybe it has
also some invluence in this issue.
best regards
Reinhold
Reinhold
R
Reinhold - 4/23/2025 2:42:21 PM
best regards
Reinhold
Sorry, just see now I post this Issue in the wrong sub-forum .
 Admin :  pls. move this post in the right forumcapter.   thx.
Reinhold
R
I found now the right solution in this case :
I only start the Aero Tracker device and the skydemon app and I  don´t connect the Safesky app to the Skydemon app during flight..
With this set up , everything works fine !  :-)
Reinhold
