Error occuring in Inflight 1.1 on Navigo V2 4.3"
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
Tim, thought I'd better start a fresh thread for the error I'm experiencing on both the Navigo V2 4.3" & generic Chinese 4.3" GPS units. Both run WinCE5 & .net 2 . The error message is:
"SkyDemon.exe
Error
An unexpected error has occurred in SkyDemon.exe
Select Quit and then restart this program, or select Details for more information.
An error message cannot be displayed because an optional resource assembly containing it cannot be found.
Details
Error
SkyDemon.exe
OverflowException
An error message cannot be displayed because an optional resource containing it cannot be found".
Then a long list of:
"at system.convert.ToInt32()
at Divelements.Aviation.x48531d913ebdc8ab.x3a117dc4e99db559()"
and so on
Any ideas,
Regards,
Max.
Are you getting this with the 1.1 version on this website?
I'll need a few more lines of those details to look in to this; thanks!
Max_UK
Max_UK
Tim, I can confirm that it is SkyDemon Inflight Version 1.1, downloaded from your site.
Confirmed again this afternoon - error 3 minutes after Satellite lock.
The full error text is below (hope not too many mistakes - it is a hard one to copy manually)
SkyDemon.exe
Error
Click "Details"
Error
SkyDemon.exe
OverflowException
An error message cannot be displayed because an optional resource containing it cannot be found.
at System.convert.ToInt32()
at Divelements.Aviation.Mapping.x2f1599f2099aaa05.x41827d71b368ba0c()
at Divelements.Aviation.Mapping.x2f1599f2099aaa05.xe406325e56f74b46()
at Divelements.Aviation.Mapping.x2f1599f2099aaa05.Paint()
at Divelements.Aviation.x08534a347ae9fc7.OnPaint()
at Systems.Windows.Forms.Control.WnProc()
at Systems.Windows.Forms.Control._InternalWnProc()
at Microsoft.AGL.Forms.EVL.EnterMainLoop()
at Systems.Windows.Forms.Application.Run()
at Divelements.Aviation.x867eb3246b182488.xc4478091322395()"
Click "Quit".
"Fatal Application Error
Application SkyDemon.exe has performed an illegal operation and will be shut down.
If the problem persists, contact the program vendor.
Program: SkyDemon.exe
Exception: 0xC0000005
Address:02A9B2D8
Click "OK" & prog exits.
Regards,
Max
P.S. The spellchecker seemed totally confused by this note.BigGrin
Thanks, I'm not surprised the spell checker didn't like it!
Would you mind contacting me through the link at the bottom of the home page? I'll then be able to send you a test build which will log a few details and will hopefully help us get to the bottom of this.
Cheers.
