Reverse route direction in flight
RainerM
R
Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)Too Much Forum (668 reputation)
Posts: 26, Visits: 160
On my last flight, I started SkyDemaon in planning mode to make sure that the correct course was loaded.
After runup, I had to refuel and switch off all the electronics again.
I then took off in flight mode, stupidly without again checking the flight plan.
For some unknown reason, SkyDaemon had reversed the flight direction.
To correct the flight direction during the flight, I had to switch off SkyDaemon flight mode, reverse the route and start flight mode again.
Is there an easier / better way to reverse the route in flight mode?
Gerhard66
G
Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)Too Much Forum (6.5K reputation)
Posts: 175, Visits: 358
RainerM - 8/25/2024 8:42:17 PM
Hi Rainer,
the route can be reversed in flight mode:
