Swipe up the HSI instrument
Laponia
L
Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)Too Much Forum (53 reputation)
Posts: 4, Visits: 0
On a tablet or phone, you can swipe up the HSI instrument from the bottom so that the entire instrument becomes visible. Is there a way to do the same when using SD on a PC running Windows? In other words, to make the entire instrument visible?
Edited 12/4/2023 4:02:39 PM by Laponia
Laponia
L
Posts: 4, Visits: 0
Just got this answer from Hannah at SD…
” No, the in-flight navigation tools in the PC software are quite rudimentary compared to the full mobile apps for iOS/Android, so the functionality is not quite as developed. It’s not possible to drag up the compass rose like you can on mobile, but it’s worth noting that you can switch to a separate Instrument View via the main navigation menu (see screenshot below), which gives you a full-screen view of the HSI.”
