Using Multiple Devices
fdemon
fdemon
Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)Too Much Forum (477 reputation)
Posts: 17, Visits: 97
The web site says you can use SD on two pcs and two mobile devices.
I have just bought a new tablet to run SD but would like to keep the old one as a back-up. I also have a copy of SD on my phone.
Can you confirm the limit of two devices is two active at any moment; you can switch between more devices as long as only a maximum of two are logged in?
Posts: 632, Visits: 31K
fdemon - 11/17/2022 5:38:37 PM
Yes. I have twoi iPads for navigation which I keep permanently logged in. I also have an old phone which use purely as a traffic display which I only ever log in from time to time just to update the chart and UK AIP just in case I needed to use it in an emergency.
fdemon
fdemon
grahamb - 11/17/2022 5:46:34 PM
I take it from that, if you did fire up your phone, you are confident that it would run as long as the iPad that caused the emergency was logged off.
Incidentally I tried AirMate and Easy VFR as my back-up option but both insisted on a later version of Android. SkyDemon however runs just fine on Version 5. Just another sign of SkyDemon's professional approach to software development.
fdemon - 11/18/2022 12:52:13 PM
Yes.
